MXM503N came with U2-50 after firmware upgrade
  • rayjeek
    • Jun 2010
    • 239
    [Error Code] MXM503N came with U2-50 after firmware upgrade
    I have MXM503N which I noted that the firmware was very old (01.02.j3) hence decided to upgrade. Having put the u02.04.j3 version it came up with U2-50 code. I came home to realised that I loaded the U model firmware instead of the N model.
    This error had happened to someone before having checked the old postings. According to the posting, he uploaded the N model firmware and then cleared code with Sim16 and MFD was recovered.
    My question is that does anyone knows whether the upgrade should be done as emergency firmware upgrade or by the normal method.
    NB: The zip file indicates N model but the content is for U model. Read the main description for firmware instead of the zip file.
  • igi
    • 1507
    Re: MXM503N came with U2-50 after firmware upgrade
    hi can happen do sim-16 to clear
    ps make sure you using the correct firmware
    good luck
    • igi
      • 1507
      hi try normal first,if fails
      then do the emergency upgrade,fairly easy
      good luck
      • rayjeek
        • Jun 2010
        • 239
        Problem solved by uploading the latest N-model firmware. However, it came up with U2-22 and U2-05 which I cleared with Sim16 to get the MFD up and running again. Customer's email settings etc. intact. Thank you all.
