AR-M276 with ARFX7 fax module, junk in memory
  • bermik
    • Jun 2025
    Hi all,
    Not very experienced so please excuse any noob questions comments from my side
    I have had problems with drained battery resulting in error code. Wanted to give machine a chance to live another year or so so i exchnged battery. I expected to have to enter all settings again but it seems the data was somehow corrupted. Now when i try to add new destinations via webinterface i keep getting error [1255] (destination adresses already full with 500 posts). When trying to enter my own faxnumber it also says memory full although nothing is there. I have cleared a lot of junk information and tried to reset using sim.
    sim 66-10
    sim 66-2
    sim 66-3 (had ng-errors on all, now showing blank and stuck in executing....)
    I get a signal from line using "speaker" but no dialing when i try to send fax.
    I would like to do a full reset of fax-module, can anyone point me in the right direction. flash on card says v02.08. Can i reflash software or something? Thankful for any help!
  • igi
    • 1507
    Re: AR-M276 with ARFX7 fax module, junk in memory
    hi reflash the firmware
    for copier and fax
    good luck
    • bermik
      for copier and fax
      good luck
      How do I flash and where do I get the firmware?
      • igi
        • 1507
        hi contact your support team/dealer/sharp supliers
        good luck
        • bermik
          good luck
          Thanks igi, Only temps and answering machines, summer times... Can't get hold of the firmware, if anyone has it send me a PM.
          • tr210907
            • Jul 2011
            • 40
            Try Sim 66-10
