MX-7000 with washed out color...problems doing ACC
  • txcharlie
    • Jul 2025
    [CQ] MX-7000 with washed out color...problems doing ACC
    Just did a color maintenance on machine due to washed out color. It is slightly better, but still not what it should be. I have not been able to do a ACC because it does not recognize the 11x17 paper in the machine. I have tried it through simulation and also through Admin, but both ways say to load 11x17 into the tray, Any help would be appreciated.
    Charlie
  • Dark Helmet
    • May 2009
    • 853
    Re: MX-7000 with washed out color...problems doing ACC
    After you did the color PM did you perform 25-2, 44-2,44-6,44-26 ?
    Trays 3 and 4 should auto detect 11x17. Try putting the paper in a differnt tray or the bypass. Ive seen the black and white product refuse to use tray 3&4 for ACC
    • bonnie750
      • 302
      the calibration jig is a must too!
      • mojorolla
        The Wolf
        • 2622
        This must be a 7001 as the 7000 is B/W. If you did a developer change, be sure to run SIM 44-27 to clear half tone target before running SIM 44-26. Also, be sure to rum SIM 50-22 if the drums have been replaced.
        • bonnie750
          • 302
          mx7000 is the model b4 the 01
          • txcharlie
            Yes, I did all those sims. I tried tray 3 and 4, but not the bypass. Will try that next.
            • txcharlie
              Yep, I hit those sims...MX-7000 is a color box.
              • rayjeek
                • Jun 2010
                • 239
                I have had a similar situation before on MX4500.
                You need to update the firmware to the latest version then you could get the calibration done.
                • WolfGang
                  Have you tried to do the tray size adjustment? Also I assume you are using the recommended 28lb 96 bright hammermill color paper for your test print/copy and calibration? Paper makes a huge difference on the color dragons. Just had a 6201 yesterday with terrible copy/print quality caused entirely by the paper they were using.
