AR-M450 Stops working while coping and re-boots. Sometimes will have to turn off
  • Dale Hill
    • Jul 2025
    [Misc] AR-M450 Stops working while coping and re-boots. Sometimes will have to turn off
    This copier will stop coping and re-boot other times it re-boots on it's own.
    Have checked voltage and things look normal. I'm beginning to think it is a memory problem. Trouble is I have no idea which memory it could be.
    I have had AR-336 copiers to do similar things and it was the DC power supply.
    Any suggestion on which memory modual to try or what could do this.
  • JustManuals
    • Jan 2006
    • 9838
    Re: AR-M450 Stops working while coping and re-boots. Sometimes will have to turn of
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • igi
      • 1507
      hi
      if it got hard drive,first thing should be checked
      good luck
      • igi
        • 1507
        hi again also check
        spring on the rear frame of the registration unit can fall out
        good luck
        • Dale Hill
          Originally posted by igi
          hi again also check
          good luck
          Thank you for the reply. This model doen't have a harddrive and I have checked the PS unit for the spring. So far noone has an answer or have seen the problem. Once again, I do think you for the help.
          • N�ri
            • Dec 2010
            • 7
            Hi, if the copier is connected to a network try to unplug the networkcable. If the machine stops rebooting then the problem is that somewhere in the network there is a non sharp postscript driver that trying to send at printout to the machines ip-adress and the machine can not decrypt the print information and thats why it starts rebooting.
              • 23008
              I've seen a few of these power supplies fail, and yes, they will shut down, then come back on all by themselves after a while. For me, I'd go with the power supply. =^..^=
              • Ednicarl20
                • Aug 2011
                • 25
                I've encountered with the same machine it only reboot, I reprogram the eeprom. Perhapse if this doesn't work try the power supply...
