AR-M550N ADU registration
  • mushy
    • Jul 2011
    • 12
    [Misc] AR-M550N ADU registration
    AR-M550N 2nd side registration is off by about 10 mils, the only way I can find to change it also changes 1st side
    • 22941
    Re: AR-M550N ADU registration
    Is the 2nd side image registration off in the feed direction or the cross-feed direction? Are you laying originals on the glass or feeding through the document feeder.
    Specifically test copying 1 to 2 duplex with the same original left on the glass. Is the registration correct?
    If no,
    For off-center cross-feed adjust simulation 50-5 (see pg 7-21)
    For lead edge registration adjust simulation 50-1 (see pg 7-25)
    If yes, test copying with document feeder 1 to 2 duplex. Is the 1st side registration correct?
    If no,
    For off-center cross-feed adjust simulation 50-12 (see pg 7-23)
    For lead edge registration adjust simulation 53-8 (see pg 7-27)
    If yes, test copying with document feeder 2 to 2 duplex. Is the 2nd side registration correct?
    If no,
    • mushy
      • Jul 2011
      • 12
      The problem was noticed first when printing 2 sided, 2nd side was off lead to trail,(or paper feed direction) I left the same orig. on glass and made a 2 sided copy, side 1 is right on side 2 is off 10 mills. I can't adj side 2 without changing side 1. I have a manual and have spent several hours messin with it with no luck.
        • 22941
        Sorry mushy. Since you listed no specifics I just assumed you didn't have a clue. I won't assume that you know something if you don't say so.
        But back on topic: The leading edge registration adjustment procedure is impossible to perform as listed in the manual. After four years of working on Cougars, Tigers, and Dragons, I set aside a day to figure it out. You know what I discovered? It doesn't work as written!
        I spent the rest of that day coming up with a registration adjustment procedure that does work. It's not convenient, and you have to go back and re-adjust the same things three times, but in the end you get the desired results.
        The only thing for certain I know about adjusting registration is that every adjustment in sim U50-xx affects everything else. I'll attach my procedure. It doesn't go into 2nd side printing registration, but maybe you can extrapolate something from what I put down.
        Good Luck. =^..^=
        • mushy
          • Jul 2011
          • 12
          Thanks Blackcat, I copied your procedure and try it out in the next few days and let you know how it turns out
