MX-5001N
  • yousaf
    • Jun 2010
    • 43
    MX-5001N
    hi
    any body knows how to deal with this error i reset the error after again it come again error code is H4-01, i for get to write modle number mx-5001N sharp
    any body help me
    bye
    knight
  • JustManuals
    • Jan 2006
    • 9838
    Re: MX-5001N
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • bilyahn
      • Dec 2006
      • 1470
      Re: MX-5001N
      Did you try to clean the thermistors or reset the thermocouples for the fuser? If you did this an you are still having this issue here are the steps to try.
      Good luck.
      Bil
      Trouble contentDetail PCUCause The fusing temperature does not reach the specifiedlevel within the specified time from turning ON thepower relay.Thermistor trouble.Heater lamp trouble.PCU PWB troubleThermostat trouble.Connector, harness connection trouble.Power unit trouble.Interlock switch trouble.
      Check & Remedy
      Replace the thermistor.Replace the heater lamp.Replace the PCU PWB.Replace the thermostat.Check connection of the connector and the harness.Replace the power unit.Replace the interlock switch.Use SIM5-2 to check the flashing operation of theheater lamp.
      Use SIM14 to cancel the trouble.
      • yousaf
        • Jun 2010
        • 43
        Re: MX-5001N
        hi
        can u plz tell me how to change administrator password
        thankssssssssssssssssssssssssssss
        knight
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          Re: MX-5001N
          Can't tell if you're a tech working on an unfamiliar brand or an end-user...
          Either way with you spamming the same question, I don't particularly feel inclined to give you the answer you seek, certainly not for free. Buy a manual and get all your answers there.
          • Dark Helmet
            • May 2009
            • 854
            Re: MX-5001N
            Sim 24-30 will reset the admin password back to admin
            Also you can edit your posts. If you check under your original post you will see a edit button. No need to start new threads.
            • Akitu
              • Oct 2010
              • 2595
              Re: MX-5001N
              Aww, had to go and give away our secret tech code huh Lawrence? Be happy you did not share the secret of our copy tech ninjitsu... Lol
              • Ednicarl20
                • Aug 2011
                • 25
                Re: MX-5001N
                H4-01, password for Admin... this is an ABC to a copier technician wonder why he is asking for this questions...
                • Akitu
                  • Oct 2010
                  • 2595
                  Re: MX-5001N
                  I believe this thread was solved/inactive earlier... Must be losing my mind!
