sharp mxm 850 POIND N JAM
  • kennyjmac
    • Aug 2025
    [Jamming] sharp mxm 850 POIND N JAM
    Hi i have 1 of these with intermittent jams only when doing double sided can be running for 200 double sided will be fine next batch jam !! it always seems to jam at the fuser and paper is folded over in half with another bit of paper in the fuser as well ,like a static problem !? any info appreciated thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: sharp mxm 850 POIND N JAM
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2627
      Oh boy where to begin on this one, let's start with the duplex:
      -adj SIM 8-20. Don't go too crazy or you will get background.
      -adj SIM 43-1 values A and B way down.
      -make sure it has a "Z2" transfer belt installed with serial # of the belt at the rear.
      -clean sensor and run SIM 44-3 -drum potential sensor.
      -try changing paper or in the large cap trays, try flipping it over. Sounds stupid, but it eliminates it as an cause.
      And as always, make sure the firmware is up to date. You can also adjust luminosity in the soft switch settings but its a long shot.
      • Silvertoast
        • Feb 2010
        • 270
        the new transfer belt, and firmware, have fixed the issue for our machines that were doin that
        • Colonel Bogey
          • Mar 2010
          • 19
          I also have a machine doing exactly the same, always when duplexing. It appears to be flipping the lead edge at the drum seperation. Speaking to other Engineers, this has always been a problem on this model. Sharp did modify the transfer belt and drum sep pawls, but my problem is on a brand new machine thats only done 200k, and the machine has latest spec. I would be interested to hear if anyone has an answer to this as well.
          • kennyjmac
            have ordered another transfer belt will see what happens with a new have turned down sim 43 1 to 160 c on a and b made a bit of diffference
            • Colonel Bogey
              • Mar 2010
              • 19
              Just tried machine with good quality paper and fault has disappeared . As soon as I switched back, the fault reappeared.. Tried Navigator Universal as opposed to the recycled rubbish they were using.
              • kennyjmac
                funny that paper ,customer has crap recycling paper as well have told them 1st time your paper is not the best !!!!!
                • nobody-here
                  • Mar 2008
                  • 237
                  Hi guys,
                  here we have same problem but without any solution.
                  firmware is f00 so should be updated (or not?).
                  Belt is Z2
                  Sim 43-01 put both A/B values to 160 degrees
                  Paper is not so bad. it's not "navigator" but it's ok
                  do you have any clue.
                  Thanks a lot for your kind help.
                  Last edited by nobody-here; 10-10-2011, 03:30 PM. Reason: tablet typing checking. :-)
                  29 rouge unpair manque.... cous cous....
                  • hammer
                    • May 2008
                    • 111
                    Hi Guys, we had something similar on an mxm1100 (new). After long runs we would get POIND_N jams, as well as a couple of other jam codes. Went down the paper route with no joy. Turned out to be the reg motor. On long runs it would heat up, bind, and slow down. Dont know if this will help you.
                    • bonnie750
                      • 302
                      Got one of these doing exactly the same. paper is too light. took in some of the recommended 80gsm weight paper and no problems.
                      Bill
                      • nobody-here
                        • Mar 2008
                        • 237
                        Bill
                        Surely paper quality is a issue, but according to me those kind of machines can't be so sensible to paper quality.
                        My customer user a medium quality paper on almost 100 machines of differente producers, (ricoh, sharp and canon) without any particular problem.
                        On 85 ppm we checked Belt and Pawls... but after last firmware update (f01) and lowering fuser temp looks isn't jamming anymore. We are going to check it on a weekly basis.
                        I'll going to keep you informed.
                        Thanks.
                        • spanky
                          • Sep 2012
                          • 468
                          We had two MX-1100 machines in the same room running the same paper and only one of the machines had this problem.
                          We tried everything on this forum and well as on the Sharp bulletins, with no success.
                          We tried replacing the pre-transfer lamp as well as a full PM including drum, charge kit, developer, sep claws on drum unit, and transfer belt.
                          We finally installed a new process unit and that fixed our problem.
