mx 2300n f2-40
  • ash_572
    • Oct 2008
    • 523
    [Error Code] mx 2300n f2-40
    what is most common problem with this error code??
    toner empty sensor obnormality.
    customer said they were getting pure black copies before this error occured.
    i have swapped the black drum unit already with no effect.any suggestions??
  • divad2k1
    • Sep 2010
    • 147
    Re: mx 2300n f2-40
    There is a new style process electrode cover to solve f2-40 trouble (prevent high voltage leak), worth a try.
    part # is: PFTAP0149FCZ2
    • greg28
      Re: mx 2300n f2-40
      This ERROR F2-40 is common to this copier try to check the level for black DV unit, try to check toner path and see if toner drops inside your Black DV unit.
      Hope you can see the results.
      • JustManuals
        • Jan 2006
        • 9838
        Re: mx 2300n f2-40
        Paul@justmanuals.com
        • Ednicarl20
          • Aug 2011
          • 25
          Re: mx 2300n f2-40
          I've encountered in MX-3500 the same error code, first I thought it was from toner cartridge due to dried toner inside and it is hard to rotate, but when I replace the black toner the same error appear. I try to check the toner pipe from toner going to DV unit, and I see that the toner was dried in the pipe. There is no toner dropping to the DV unit I only remove and clean and the error code was gone...
          Hope this can help.
          • ash_572
            • Oct 2008
            • 523
            Re: mx 2300n f2-40
            UPDATE: today i went back to change the black cartridge with no effect.
            after vacuuming out the black toner pipe i got another error code f2-42 (magenta)
            switched the machine off and on i get f2-43 (yellow)
            error code keeps on changing and its now currently on f2-42.
            customer has done 188 000 b/w and 1500 colour. machine is mainly used as a b/w
            • nightshade
              Chromographic Supremesist
              • 158
              Re: mx 2300n f2-40
              There is a bulletin on this (a couple of them). This is a problem in high humidity areas. There has been a change to the charge plate and grid for this error(s).
              Do a full PM, drum, dv, mk. Go into the sscodes and make sure our toner densities are within spec after the PM.
              There are also updated toner tubes with clickers on them to keep them from clogging. I would think about getting those changed.
              • Ednicarl20
                • Aug 2011
                • 25
                Re: mx 2300n f2-40
                It's better to dis-engage all the pipes and clean before anything else. Check also the gears in the toner if it is rotating properly.
                • ash_572
                  • Oct 2008
                  • 523
                  Re: mx 2300n f2-40
                  on arrival i had a f2-42 so i changed the magenta pcu and dev unit and alll is well. thanks
                  • WDF
                    Re: mx 2300n f2-40
                    Hello all,
                    I just bough two brand new Sharp MX 565N copiers and on both of them I have F2-40 error. I have tried with replacing toners but that did not help. Does anyone know how to enter simulation mode on this model and/or how to rectify issue?
                    Thanks in advance
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      Re: mx 2300n f2-40
                      Originally posted by WDF
                      Hello all,
                      Thanks in advance
                      If the toner cartridges were installed during shipping, the DV has overtoned. To enter diags, double tap the home key, press the version level at bottom right - then the regular # * C *.
                      Disable toner sense in TC 7, run quite a few skyshots and then check TC 25-1 to see if the toner concentration is OK. This might work for you short of replacing developer.
                      • WDF
                        Re: mx 2300n f2-40
                        Hi,
                        How to run sky shots and how to run TC 25-1?
                        Thanks a lot
                        • ZOOTECH
                          • 3375
                          Re: mx 2300n f2-40
                          Hi,
                          Thanks a lot
                          "Contact your local Sharp representative to help you out. You don't want to make the situation any worse." Thanks Akitu
                          • WDF
                            Re: mx 2300n f2-40
                            The problem is that I am offshore in Mexico and local dealer don't speak English and I don't speak Spanish but thanks anyway.
                            • ZOOTECH
                              • 3375
                              Re: mx 2300n f2-40
                              I work alot with Mexico, and while not without some problems, "Google Translate" has been very helpful.
