mx 2300n f2-40
  • WDF
    #16
    Re: mx 2300n f2-40
    Originally posted by WDF
    The problem is that I am offshore in Mexico and local dealer don't speak English and I don't speak Spanish but thanks anyway.
    Hi,
    Could you tell me how to run sky shots, I entered sim mode and I did the tests that you previously mentioned but now I need to run sky shots and I cannot find out how to do it.
    • ZOOTECH
      Senior member of CRS
      • 3375
      #17
      Re: mx 2300n f2-40
      Hi,
      Nothing on copy glass with the doc feeder open, you'll be copying the "sky". This will use up a lot of toner, but you may have to run several hundred if it's badly overtoned.
      • WDF
        #18
        Re: mx 2300n f2-40
        Hi,
        It is finally working, the problem was that I have never put developer inside, apparently it is not in manual because these machines are not meant to be installed by end user but since we are offshore we have no choice. I had to open DV unit and clean it completely and put developer inside and run sim 25-02 without toner then I installed toner and everything works perfectly.
        Thanks for all the help
        • ZOOTECH
          • 3375
          #19
          Re: mx 2300n f2-40
          Hi,
          Bravo; when you said you got two new machines, I didn't realize they had never been set up.
