ar-5132
  • T911
    • Jun 2007
    • 628
    ar-5132
    this one had a h5-01 code on it, i returned with the fuser unit and power supply but now it is tripping a L4-01 code. i checked the drive for any drag but no luck. the main motor spins for about 2 seconds and then trips the code. nothing broken in the drive all connections are in. retraced my steps but no luck. any help appreciated. thanks t
    • 23009
    H5-01 is not strictly a fuser code. Technically its a jam condition. To get an H5-01 you must get (3) consecutive fuser jams.
    If your getting fuser jams and main drive errors, the logical first place to look is fuser bearings, or something in the fuser drive. I've never had a drive motor failure, but lots of bad fuser bearings, or maybe a seized developing unit.
