AR-208D toner is low message
  • ron67601
    #16
    Re: AR-208D toner is low message
    Humility means modest opinion, maybe you should try that then. I wasn't giving an opinion, I was asking for one and I still haven't gotten one.
    • Jaws
      • Oct 2007
      • 236
      #17
      I have an opinion. I suggest putting a piece of tape on the screen to cover the words toner low. Won't look as pretty as removing the message but it will give the same results. You will still have a problem that the machine wants/needs more toner.
      Sorry, I just thought I would state the obvious encase you rode the short bus.
      P.S. I am the devil
      • ron67601
        #18
        Your a sandwich short of a picnic.
        • PASTech
          • Sep 2010
          • 192
          #19
          It appears that there is no method for disabling the Toner Low message. It will always appear when the toner is detected at 12.5%. Unless there is some dip switches which no one, except Sharp, knows about. If this is a serious problem for the customer then you should request information from Sharp.
          There is my opinion based on the research and searches I have conducted.
          Can I get a super sized quadruple big mac with extra cheese and bacon on a sesame seed with bacon bit bun...
          yum....
          What's Brown and Sticky?
          -A Stick
          • ron67601
            #20
            Finally, I got the answer I was looking for. Thank you so much. At least there is some sensible people out there.
            • Ctl-Alt-Del
              • Jul 2006
              • 430
              #21
              Originally posted by ron67601
              ...At least there is some sensible people out there.
              And then there is you.
              • DINGO
                • 661
                #22
                Blackcat, .
                there are things, that the best is to ignore.
                my best regards Sir
