Sharp MX-M623
  • Gabriel
    • Jun 2006
    • 141
    Sharp MX-M623
    Here is the problem:
    Customer have the user name and password list, but I can't pass the user authentication screen.
    trying to go into the copier web page I got a message "Can't access the controller try again later."
    I have access to simulation mode and able to print, but I'm not familiar with this model.
    Any help will be appreciated
    Regards
    Gabriel
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp MX-M623
    Are you able to log in as an admin? Can you make user changes from the web page?
    • Gabriel
      • Jun 2006
      • 141
      Re: Sharp MX-M623
      Akitu
      Thaks for your fast response:
      No, I can't.
      From the touch screen I can select any of the users already in the MFP and the password button, also I can type the password with the numerical keypad
      When I type the IP address in the browser (IE) after a while I get this message:
      "Can't access the controller try again later"
      Regards
      Gabriel
      • Akitu
        • Oct 2010
        • 2595
        Re: Sharp MX-M623
        Originally posted by Gabriel
        Akitu
        No, I can't.
        Regards
        Gabriel
        Do a NIC reset with sim 67-17, you'll lose your network settings but should be able to access it afterwards, if not I'd be inclined to think your network card blew. Is it a U or an N model?
        • Dark Helmet
          • May 2009
          • 867
          Re: Sharp MX-M623
          If authentication is enabled there should be an admin button. Password should be admin, all lower case. If this has been changed you can reset it using sim 24-30.
          If that lets you login enter system settings and do a factory reset on the NIC from the network settings menu. As Akitu said 67-17 will reset all your configurations in network settings on the webpage.
          • Gabriel
            • Jun 2006
            • 141
            Re: Sharp MX-M623
            It's an N model.
            I don't see an administrator button,
            Looks like authentication is enable, is there a way to disable authentication from simulation?
            also, how can save the network settings from simulation mode. 'cause simulation mode is the only way I can access the MFP.
            Regards
            Gabriel
            • igi
              • 1507
              Re: Sharp MX-M623
              hi
              Gabriel all the sugestions from others is 100% correct
              if you stil not coming right, then you must have hardware failure
              1-nic
              2-mfp
              good luck
              • Dark Helmet
                • May 2009
                • 867
                Re: Sharp MX-M623
                Lets see if the service web page works.
                Enter the specifiedURL (http://xxx.xxx.xxx.xxx/service_login.html) and enter the servicing page menu.
                Default password: "service"
                The password can be optionally changed in the Password
                Setting menu.
                If the password is changed and forgotten, use SIM24-31 to
                reset the password to the default.
                You can access user control here by the looks of it.
                I think im going to agree with IGI. If you can't access the service webpage knowing you do have the proper IP of the copier then your NIC has probably kicked the bucket which means a new MFP which is going to hurt.
                • Gabriel
                  • Jun 2006
                  • 141
                  Re: Sharp MX-M623
                  Thanks all you guys, I'll stop today at customer office and will post back.
                  Regards
                  Gabriel
                  • Gabriel
                    • Jun 2006
                    • 141
                    Re: Sharp MX-M623
                    Thanks to everyone
                    After resetting the NIC card, Machine is working fine.
                    Regards
                    Gabriel
