ar 550
  • bonnie750
    • 302
    ar 550
    Customer has emailed a scan of this problem and i haven't been to see it yet but it sounds/looks like a strange one.
    single sided copies are fine but when duplexing both sides are overtoned to the extent that the toner seems
    to bleed through the paper. The machine had 250k on after refurb. I'm thinking transfer problem but open to ideas
    before I drive to customer which is a long way out.
    any input will be useful
    Bill
  • JustManuals
    • Jan 2006
    • 9838
    Re: ar 550
    Paul@justmanuals.com
      • 23006
      Re: ar 550
      Just to clarify: Is this a AR-M550N, AR-M550U, or FO-DC550.
      There's a small difference of 50cpm and 450#. Our dispatchers never seemed to think it made any difference. =^..^=
      • bilyahn
        • Dec 2006
        • 1470
        Re: ar 550
        Actually a common problem with these. When doing 2-2 sided the image will bleed through but not when doing 1-2 sided or single sided. That's why the newer models have the top and bottom scanners offset. Check your 46-2 auto settings and make sure they are set to 50 or less. If they are above 50 that can cause it. You can do a white reference calibration and make sure your ROM version is current also. I have seen it also caused by the scan cnt pwb but that was only 1 case.
        Good luck.
        Bil
        • bonnie750
          • 302
          Re: ar 550
          Hello
          apologies blackcat its an arm550. Bilyahn, yeah i've heard it's sometimes an issue on these. I'm going there monday or tues and i'll post my findings
          Bill
