ar-m620n
  • gregu33701
    • Oct 2008
    • 31
    [Jamming] ar-m620n
    jamming code mprd2_n2 , basically jamming out of tray 2 paper deck when running more than single copy, single copies out of tray 2 run good, tech in feild had already changed paper feed parts in tray 2, i removed the funnel assembly cleaned and repladed d2 sensor with new, one way one d1 roller shaft seems to be good as well
    thought i remembered a post a couple of years ago having to do with deck lift motor
    any insights?
  • mojorolla
    The Wolf
    • 2627
    Re: ar-m620n
    You are correct about the lift motors. There are also bulletins about the torque limiter shaft slipping (worn pin) and the addition of poly sliders to the shaft ends. MFP-TB-172,MFP-TB-438, and
    MFP-TB-224
      • 23009
      Re: ar-m620n
      You're going to love this one. I sure did:
      Misfeeds (jam code MPFD1_S, MPFD_NM) from the bypass, (jam code MPRD2_N2) from tray #2 only. Flipped corners and skews into the finisher tray. Premature fuser roller failure. Unsuitable coated media (specifically posters) are fed through the bypass, coating the tires and horizontal path rollers and damaging the fuser rollers. Clean bypass tires and horizontal path rollers. Rebuild fuser. Advise against use of coated paper.
      Twice in one day on the same machine.
      • mojorolla
        The Wolf
        • 2627
        Re: ar-m620n
        Well I'll be a monkeys uncle...
