asharpdesk
  • DINGO
    • 661
    asharpdesk
  • spotlifter
    • Mar 2008
    • 65
    Re: asharpdesk
    May we know what model of this copier would be? What version of sharpdesk would this be?
    Anyway, have you try log in the copier and look at the addresses? Maybe the profile is already there?
    sigpic
    • igi
      • 1507
      Re: asharpdesk
      Hi Dingo
      make sure firewall is off,then antivirus is off.
      one more thing to try go to:
      1-internet explorer options
      2-connections
      3- under lan settings set it to auto detect
      good luck
      • Toner Boy
        • Aug 2007
        • 366
        Re: asharpdesk
        Or confirm with a laptop running the NST and X-over cable to eliminate network issues. It is best to clear out any existing profiles on the machine through the web interface.
        • DINGO
          • 661
          Re: asharpdesk
          thanks friends.
          've checked everything.
          The instalation is in a office, and there are more pcs, that works good, and are three copiers, 450;451 and mx 2300. all in the same network.
          -i m using the latest sharpdesk version.
          -now i m think in one thing, there are a sharpdesk windows xp version?
          thanks at all
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: asharpdesk
            Originally posted by DINGO
            thanks friends.
            thanks at all
            There is a WIN 7 version that is backwards compatible - 3.3v1.30.
            • DINGO
              • 661
              Re: asharpdesk
              today I walked around a problem, I could detect, but could not solve.
              -it hapened when i try save the scann profiles, in the windows xp, with the mx-2300, only.
              -for exemple
              -i instal the sharpdesk, update the scaners, ar-m451, and ar-m450, save the profiles ok. everithing work ok.
              -now, if i add a mx-2300 scanner, add ok, but when go save the profiles,the sharpdesk
              crash, give me "unknow" error, and do not work more, every profiles are deleted of every
              copiers, only with a new instal without the mx-2300 of corse, can work again.
              -it hapened in the two pcs tha have a windows xp in the network, with the others pcs with seven and vista, no problem.
              -of corse i already try with every sharpdesk versions.
              good night
              • DINGO
                • 661
                Re: asharpdesk
                Hi friends
                I`m posting here the solution for mi issue.
                The issue was in the pcs that have windows xp sp3 + sharpdesk with scanner tool + more, and this is the problem antivirus eset, or nod 32 v. 4 and five.
                the solution after many, many, time studing the problem, is replace the antivirus aplication.
                May be, is useful for someone.
                • igi
                  • 1507
                  Re: asharpdesk
                  Hi
                  Dingo tanx for letting us know about the solution
                  will go to the memmory banks.
                  cheers
