MX-2610 Trouble Codes U2-40,U2-41,U2-42 effecting on Equitrac systems.
  • rgcs1
    Systems Intergrator
    • 69
    Hi all, we have recently been putting out Sharp MX-2610 to Schools & academies (150 in total) All machines are on Equitrac and have been working ok.
    We are now experiencing Trouble codes of U2-40,41 & 42. on certain machines, all firmware is up to date on the sharps and the equitac is running ok.
    We have noticed that this only happens on Sharp machine that run Equitrac.(But not all of them) We have other MX-2610's that dont run equitrac and there are no issues with these.
    We have also re-formatted the HDD just as a percaution. Made sure that the SD card is ok.but still comes up with codes.
    Sharp Uk are not aware of this problem and have no answers at present.
    We have contacted Equitrac and no one has heard of this problem.
    The only solution we have so far is to turn Off/On machine and the codes disappears for a few days but then comes back.
    Any help or advise on this would be much appreciated.
  • mojorolla
    The Wolf
    • 2627
    Re: MX-2610 Trouble Codes U2-40,U2-41,U2-42 effecting on Equitrac systems.
    I would try backing up the SD cards, format them, then push the settings back in after the format. There are known issues with SD cards of 4GB or larger and these use 4GB according to the manual. The manual also does not specify if it is SD, SDHC or SDXC. These models appear on the Equitrac site as supported. The Sharps listed require the external account module option as well.
    • rgcs1
      Systems Intergrator
      • 69
      Forgot to mention that we have Backed up the SD Card and pushed settings to another Sd card.
      They all have the "External Counting Module" fitted already.
      Thanks for you reply
      • igi
        • 1507
        Hi
        if possible swop the copiers around
        the one with problem remove the Equitrac and use as normal
        hope that will help to identify,if the problem with the copier or not
        good luck
        • mojorolla
          The Wolf
          • 2627
          I know on Ricohs, the PCC must be installed on the SD card and not the HDD.
          • londonricoh
            have tried formatting hard drive and switching on auto format in HD trouble however codes u240,41,42 keep appearing on our 2610's running equitrac however our 2610's running papercut show no errors similar
            • londonricoh
              *********Update
              Affected machines show no further sign of error codes U2-40 , U2-41 , U2-42 following procedure............... 1. clone device
              2. perform sim 62-01 hd format
              3. adjust sim 62-12 auto reboot in hd trouble
              4. re-clone saved data
              • Dustin(WOP)
                • 223
                Pretty sure I saw a firmware update for this issue about a week ago. Check IDNC.
                • londonricoh
                  Hi Dustin. Im based in UK and dont currently have access to IDNC. Can you verify the firmware?
                  Thanks in advance
                  Londonricoh
                  • whizaway2
                    Hi Peeps I have had a similar problem with a mx5112 on an equitrac system with a biometric finger scanner showing a CE-02 error, scanner problem. It appears 3+ times a day, mainly 1st thing in the morning, turn off/on temp. cures fault. We went to the trouble of swopping machine to prove either machine or equitrac, new mcn threw up error same day! Customer also has mx3110's on site with no problems. I'm thinking strange signal or interference on network? I have heard ver7 firmware is an issue but don't what the issues are,my machine is on ver8
                    any one with any ideas would be much appreciated
                    Sharp have no idea
                    • Akitu
                      Legendary Frost Spec Tech
                      • Oct 2010
                      • 2595
                      Sharp have no idea
                      CE-02 is a network connection issue. If your IP address is blocked by firewall, swapping machines won't do a thing for you. Is it connected wired or wireless (through an AP)?
                      A few posts above you, someone posted their solution; though it was for the U2 error codes.
                      "*********Update
                      4. re-clone saved data"
                      Double check the entire thread for some possible solutions, maybe try starting your own next time instead of piggybacking off another thread just because it has "equitrac" in the name. Sometimes people skip 2 year old threads that get needlessly bumped to avoid reading a bunch of info they may have already read.
