E7-11 only when trying to scan
  • BMSInc95
    • Sep 2011
    • 66
    [Error Code] E7-11 only when trying to scan
    Have two machines doing this. Both have the correct firmware. One machine got a new ccd.
  • BMSInc95
    • Sep 2011
    • 66
    Re: E7-11 only when trying to scan
    Oh sorry both are ARM-205. both using USB scan.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1885
      The only ones we've had do it, the firmware fixed.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • mojorolla
        The Wolf
        • 2616
        Firmware has always fixed these for me as tmaged mentioned :
        Subject: ROM Version Upgrade (December 2006).
        Description: The firmware for the above model has been upgraded from December 2006 production.
        Executed from the production in December, 2006
        Model: AR-M205 / ARM160
        ROM Control No: B06
        MCU: V03.01
        Model: AR-5132
        ROM Control No: A02
        MCU: V01.12
        Corrections made:
        1. The operating margin for occurrence of E7-11 error (Shading trouble /White correction) has been increased.
        2. Since the E7-11 error may occur due to fogging of the reflector, the E7-11 error detecting level has been decreased
        • tmaged
          • Oct 2008
          • 1885
          Confirm Copy Lamp is lit
          Clean lamp reflector & all mirrors
          Confirm lamp reflector is in place & correctly positioned
          Ensure mirror base is totally parallel with mirror B
          Check CCD skew
          Last resort - Adjust CCD height by half turn maximum
          Hope that helps !
          -Tony
          www.dtios.com
          • Dexter123
            Hi
            If the E7-11 only occurs when you do colour scans from the document feeder then there are two thing you can try.
            1) When you take out the slit glass there is a white reference at the rear of copier can sure it is white, if you can not replace it, paint on the glass with a tipex pen (not bottle of tipex must be pen) where the reference is. IMAG0135.jpg
            2) Replace the copy lamp, if the lamp is on and there is a grey piece at the ends then is must be replaced. With new lamp the light goes all the way to the edge of the lamp.
            Hope this helps.
            • BMSInc95
              • Sep 2011
              • 66
              Only one machine had the current firmware but reflashing both seemed to work. We'll see.
