MXM310N Maintaince Required after PM
  • redserv
    • May 2010
    • 307
    hello guys i did a PM on MXM310N about 2 weeks ago,changed drum and dev, i cleared all counters etc.... client called yesterday, said they are seeing Maintaince Required on lcd screen, so i went back to the client and yep i saw it for myself, i checked Sim 24 and the drum and developer was only doing 13,724 copies, so i am abit stumped here, was there something i messed up on when i was doing the PM? can someone point me in the right direction please.thanks in advance
  • bilyahn
    • Dec 2006
    • 1470
    Re: MXM310N Maintaince Required after PM
    The only thing I can see is this statement from page 8-31 in service manual. But it applies to sim 24-4 which is the simple maintenance reset. I don't see how this may be helpful but it's all that I can find so far, nothing on the sharp website that I could find for this model. What is the meter on this?
    Good luck.
    Bil
    31 sheet model: When maintenance message is displayed, replaceconsumption part reaching the number of sheets of maintenance,
    then clear the replaced part's counter only.
    • Dark Helmet
      • May 2009
      • 868
      When replacing Drum and DV you should reset:
      24-4 M-Count
      24-5 DV Count
      24-7 Drum Count
      Double check the M-Count preset in Sim 21. It should be set to 5 for 150k. If it's set to 1 it will pop the counter at 10k.
      Also check to see if sim 26-6 is set for your country. Maybe if the machine is set for the middle east they mess around with the m-count preset. I know when you set a new machine from USA to Canada the energy savings are set for 1 minute on auto shut off vs 10 minutes in theUSA.
      Just out of curiosity, did this box have network already installed out of the box? In Canada we can't get a "N" model and have to add every option to the machine. I think it's pretty retarded that Sharp was not putting network in these right out of the box. It also needs a color scanner and this would be the perfect machine for a small office...... The engine is a brick Sh!t house and that feeder works really well.
      • bilyahn
        • Dec 2006
        • 1470
        I agree with you on the color scanner would be a major plus for this machine. In the USA we have to install each part, print, scan memory, fax, etc! Very annoying for us as well.
        Bil
        • spotlifter
          • Mar 2008
          • 65
          Code:
          Maintenance:  MX-M310
            100k                       Interval:
                                            [U]Process Section:[/U]
                                            Replace Developer
                                            Replace OPC Drum
                                            Replace Drum Cleaner Blade
                                            Replace Main Charge Unit
                                            Replace Ozone Filter
                                            Sim 24-05 Clear Developer Counter
                                            Sim 24-07 Clear Drum Counter
                                            Sim 25-02 Toner Concentration Adjustment
                                            Sim 24-04 Clear Maintenance Counter
                                            [U]Paper/Feed & Transport:[/U]
                                            Check/Clean/Replace PF Rollers
                                            Sim 24-01 Clear Jam Counter (if required).
                                            Sim 24-02 Clear Individual Tray Counter When P/F Rollers are replaced.
                                            [U]RSPF:[/U]
                                            Clean all RSPF/RSPF sensors.
                                            [U]General:[/U]
                                            Clean all optics, CCD, and white reference plate.
                                            [U]Image Quality:[/U]
                                            Sim 40-02 Adjust Copy Exposure Density(B/W).
                                            [U]Other:[/U]
                                            Sim 22-05 Data Print
            150k                       Every 150k Interval (perform the additional procedures):
                                            Replace 150k Maintenance Kit:-
                                                            Drum Separator Pawl Unit x 2
                                                            DV Blade
                                                            Transfer Roller Unit
                                                            DV Side Sheet F
                                                            DV Side Sheet R
                                                            Toner Filter Unit
                                            [U]Fuser Section: [/U]
                                            Replace Upper Heat Roller Kit:-
                                                            Upper Heat Roller
                                                            Fuser Gear
                                                            Upper Heat Roller Bearing x 2
                                                            Upper Cleaning Pad
                                                            Fuser Separation Pawl Upper x 4
                                                            Thermistor Cleaning Pad
                                            [U]Transfer Section:[/U]
                                            Replace Transfer Roller Unit
          Thank you to warren.
          sigpic
          • redserv
            • May 2010
            • 307
            ah, thanks alot guys i will take closer look into to this, appreciate the feedback
