ar-m207 printing blank copies after i cleaned it, could i need to replace the develop
  • astricker
    So today our boss was gone and we decided to clean our sharp copier. I took the toner out and it was pouring out so before i replaced it w the new one i wanted to clean up the mess the old toner made. so I unscrewed 1 screw and took the sleeve out and blew it off w canned air I did the same w the drum. Now all my copies come out blank. could it be that i need to add developer now? please help before out boss gets back.
    • 23009
    Re: ar-m207 printing blank copies after i cleaned it, could i need to replace the dev
    Oops.
    What you cleaned out was not toner. It was developer. And the roller you removed had some precision adjustments which are now un-adjusted.
    This post describes what developer does: http://www.copytechnet.com/forums/ra...tml#post248768
    I recommend that you hire a competent tech to clean your machine and install developer and possibly replace the developing unit. =^..^=
