mxm 450 E7-90 code
  • jpcopy
    • Apr 2006
    • 256
    mxm 450 E7-90 code
    any fixes for the E7-90 code on a mxm450. book don't help or I can't read it properly . this code has popped up a few times and popo reset it but there must be a cause
    any help appreciated
  • PASTech
    • Sep 2010
    • 192
    Re: mxm 450 E7-90 code
    I would just start resetting connectors between the PCU PWB and the MFP PWB. Is the firmware up to date?
    The manual also says about broken pins on the PCU PWB, Might be tedious but it's worth finding the problem before you just start slapping in boards, unless you have a parts machine to try out boards from.
    After that I might consider using a sledge hammer......not that I h ave done that...just a suggestion.
    What's Brown and Sticky?
    -A Stick
    • mojorolla
      The Wolf
      • 2630
      This is a known issue for this model. Replace the PCU flash ROM or rewrite to a known good ROM.
      • jpcopy
        • Apr 2006
        • 256
        thanks guys for replying. we did the reconnecting the connectors thing. the rom answer will probably be where we will go with
        thanks again
