Sharp Network Faxing
  • mansart
    • 852
    At machine inserting a pause into the number is as simple as touching the pause button, but how do you insert a pause into.....
    1. Network Fax print driver
    2. When setting up the Address Book on machine internal web page?
    Also is it possible to program a set prefix to all numbers on a MX363 with fax board. In other words my client must dial 9 (pause) 9 (pause) in order to get a line. Can you program the 9 (pause) 9 (pause) to be a prefix that the machine will auto dial before fax number?
  • mojorolla
    The Wolf
    • 2618
    Re: Sharp Network Faxing
    I always add the nine in the address book. I believe there is also a default setting in the fax soft switches. Switches 2 and 3 deal with pause time
