Help mx-c311 stopped working e7-22
  • davidcorp
    • Nov 2011
    • 16
    [Error Code] Help mx-c311 stopped working e7-22
    Hi everybody, I've a big problem with my sharp mx-c311, today in my copier appear an error e7-22 and suddenly it stopped to work.
    Could someone help me?
    Davide
  • mojorolla
    The Wolf
    • 2586
    Re: Help mx-c311 stopped working e7-22
    That code is a problem with the laser for magenta. You could be looking at a new laser unit. If you are not a technician, you should call one for this error. You could try cleaning the slit glass for magenta...
    • harleyrider
      • Oct 2011
      • 348
      bad laser unit
      • davidcorp
        • Nov 2011
        • 16
        Thanks for the support, I've tried to call the nearest tech support but I've to wait too much...
        If there is a service manual with picture maybe i can try to restore my fax - scanner - copier - ...
        After that, have I to make a reset procedure for remove the e7-22 code and test if the problem is gone?
        Davide
        • davidcorp
          • Nov 2011
          • 16
          Nobody could help me?
          Could someone explain me how to clean the laser unit? Or What I've to do to verify that it's broken?
          Davide
          • Nachoman4life
            • Oct 2007
            • 212
            Has the code happened only once? Have you reset the machine using the main power switch? Has any tech support asked you to do a "14"? there is no end user cleaning that will fix this, the highest probability is the magenta laser diode has failed, all 4 color(S) diodes are on one pwb, if one fails the whole board needs replaced. Second is the beam detect board has failed. (Both within the laser unit) This is not an end user repair. A green tech would replace the whole laser unit, a experienced tech could do the board itself. Find a repair person that will quote you both prices. Do not try yourself, unless you are a tech, its a very delicate unit, and will cost you ALOT more if you fail repairing it yourself.
            Where the heck is my spring hook?
            • davidcorp
              • Nov 2011
              • 16
              I've reset all code with the simulation test, but nothing happened... I've cleaned all two times, and all two times, the machine restart, but after 50 copies, the code returned...
              I've removed the lsu unit and verify that the 4 glass are perfectly clean, so I think lsu need repair.
              Now I'm try to call a tech support to send my copier.
              Davide
              • PASTech
                • Sep 2010
                • 192
                Good Call, this is definitely a technician job to do.
                What's Brown and Sticky?
                -A Stick
