Sharp ARM207
  • Vesigoth
    • Mar 2008
    • 133
    Sharp ARM207
    Trying to connect this machine to the network (TCP/IP) I go into Key Operator Settings arrow down to "Energy Save" setting and can't get any farther than that. The next item on the menu should be "Network Settings" but it won't display this setting. Any suggestions would be appreciated. Thanks.
  • mojorolla
    The Wolf
    • 2622
    Re: Sharp ARM207
    Are you logged in as the administrator?
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Re: Sharp ARM207
      I do believe on those machines it's still considered a key operator. Though you are correct. 00000 default code for key op. 22-7 to display it if it has been changed.
      (Almost wrote in 24-7, big difference, whoopsies!)
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: Sharp ARM207
        I assume you have the ARNB3 print controller and the USB cable is going to the to the top USB2 connector of the machine, right?
