MX4100 PPD2_PRI
+ More Options
Posts
  • DINGO
    • 661
    #16
    Thank you friends.
    I have one mx 2700 that gives me ppd2-pri.
    I have the last pcl6, print drive and the copier is updated with the firmware?
    Wath i can try more?
    • DINGO
      • 661
      #17
      fix
      Hi friends
      After a lot of hard attempts, i fix this with replacing the print drive for the print drive of the model mx-2310u.
      In mi case mx-2700 in windows 7 32bts.
      Work fine with the mx-2310u drive.
      I hope this was usefull for someone
      • DINGO
        • 661
        #18
        Re: MX4100 PPD2_PRI
        hello
        for someone with less experience.
        -yet about using mx-2310 w7 print drive in sharp mx-2700.
        -when a new intall do not install using the mx-2310 exe. aplication, because do not detect de device, because the device
        ois not a 2310.
        -so, first instal using a version drive for mx-2700, and after in the print drive interface, change the drive manualy by the mx-2310 drive.
        -or install using "add a print", create a new ip port, and choose tha drvie mx-2310.
        hope do not forguet anything.
        enjoy
        • tonasis
          • Oct 2015
          • 10
          #19
          Re: MX4100 PPD2_PRI
          I just had this on an MX-2310U
          No security kit fitted
          I cleared down the job q on the device, then tested copying and printing, all OK
          Suspect that a corrupt print job was root cause.
          Hope this helps someone else in a sticky situation!
          • sharphead
            • Aug 2009
            • 285
            #20
            Re: MX4100 PPD2_PRI
            I have this jam code on a mx-2310u in a customers a good distance away.
            They have two so swapped the departments they were in and cleaned memory module and formatted hard drive.
            Thinking next step I might swap the memory modules.
            I've just read the link on drivers so will try that while on site.
