Sharp mx-2300n Colored Lines On Paper
    • 22999
    #16
    Re: Sharp mx-2300n Colored Lines On Paper
    Was the machine plugged in when you pulled the memory? =^..^=
    • onetwentie
      #17
      I believe it may well have been yes. Oops?
        • 22999
        #18
        big oops. =^..^=
        • onetwentie
          #19
          big oops. =^..^=
          Uh oh!
          what next? Anything that I can do? Can be done? :-(
          if the memory is removed with the machine off is that okay?
          also what about the removal of the EPROM : is that also okay to remove so long as the machine was switched off?
          Has the board lost it's memory?
          thanks on advance
            • 22999
            #20
            Originally posted by onetwentie
            Uh oh!
            thanks on advance
            If you are very lucky, only the memory is dead. I can't say I've ever made this particular mistake before, but who knows? I may yet.
            So I have no experience with this situation. =^..^=
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              #21
              Zootech, Akitu
              thanks both for the replies. I had been re-seating the memory as per one of the earlier posts and swapped out one dimm from a different machine (also faulty), I have now since doing so, got the error:
              Call for service. Code U2-30.
              I've downloaded the service manual, and it says:
              "Cause:
              EEPROM is not changed when the PCU/MFPcnt
              PWB is replaced.
              Check and remedy:
              1) Check that EEPROM is properly set.
              2) Check that EEPROM on the previous PWB is
              inserted to the newly installed PWB.
              I have tried re-seating the EEPROM, but it has made no difference?
              I hope I haven't caused any further damage!
              please help.
              So... You're not a tech or you just didn't have the manual? The whole "I downloaded the manual" thing is very unnerving. Do you know what the EEPROM is? I would recommend contacting your local Sharp representative. You've done enough damage as is.
              • mojorolla
                The Wolf
                • 2590
                #22
                I believe that error code will require new eeproms from Sharp.
                Big oops indeed!!!!!
                My former boss thought it would be wise to change a light fixture with the power on a few years back. Fell of a ten foot ladder, and landed on his head.
                He can no longer remember what he had for breakfast and frequently wets himself.
                Step #1 : pull the plug!!!
                • Akitu
                  • Oct 2010
                  • 2595
                  #23
                  Well, anyone who has access to elevated sims can reprogram the EEPROM data themselves, but I wouldn't trust it to an end user who wants to play technician by downloading the service manual online.
                  • Jack79
                    • Jul 2014
                    • 312
                    #24
                    Originally posted by Transmed31
                    Hello,
                    I am having the same problems with magenta streaks coming out when I print things. If I copy things the streaks do not appear only when I print. I have opened the side and cleaned the secondary transfer belt and the drum unit which both had magenta toner on them. When I closed it back up and printed again the magenta toner came back in the same places. I want to open the unit up to get a look at the primary transfer belt but am unsure of the best way to do that. Images attached.
                    [ATTACH=CONFIG]21010[/ATTACH][ATTACH=CONFIG]21011[/ATTACH]
                    Hi I have quite similar problem. Yours above 2 pictures are like mine. I tried copy and I have problem with Magenta too. My copies look like:
                    Red lines on the top.
                    I put developing unit + drum unit (magenta) into other machine and there were no problem. I put deve + drum unit back and I insert another Magenta toner cartridge but my copies are still with this red line. My secondary transfer belt looks like yours.
                    Can anybody advise what else should I check.
                    Regards
                    • Akitu
                      • Oct 2010
                      • 2595
                      #25
                      [ATTACH=CONFIG]26864[/ATTACH]
                      Regards
                      Why did you try changing the toner cartridge? These aren't inkjet machines.
                      • lenovos
                        • Oct 2012
                        • 140
                        #26
                        It seems to me that I had a similar problem and it turned out to be the secondary transfer board. Back of copier top left.
                        • Jack79
                          • Jul 2014
                          • 312
                          #27
                          Do you mean this board ?
                          • lenovos
                            • Oct 2012
                            • 140
                            #28
                            Yes that is the board
                            board.JPG[/QUOTE]
                            • Jack79
                              • Jul 2014
                              • 312
                              #29
                              [ATTACH=CONFIG]26879[/ATTACH]
                              [/QUOTE]
                              I changed this board but it did not solve the problem. Red belt is still printed.
                              Does anybody has another idea please?
                              • igi
                                • 1507
                                #30
                                hello all I had this problem before.long time ago
                                the solution=
                                where you drum slides to the guides on the rear frame there is 2-red screws.
                                adjust them little by little until no more magenta banding
                                or was it for the developer unit try one at a time
