AR-201
+ More Options
Posts
  • rbell12
    • Aug 2006
    • 83
    AR-201
    Customer called in and says she has icon of a man and a gear on screen. We don't normally work on sharp and are wondering what we need inthe way of supplies to perform maintenance on this unit. Have already located developer and drum, just want to know if there is anything else recommended to take as this is some distance out of our normal service area. Any suggestions would be greatly appreciated. She didn't give a meter count, so, we are basically going out blind on this one. TIA, rb12
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: AR-201
    AR202DR, AR202ND, UCLEZ0009QSZZ cleaning blade. Clean the charge grid as necessary.
    • rbell12
      • Aug 2006
      • 83
      Re: AR-201
      Thank you, Akitu. Is there anything that needs to be done besides resetting drum and developer counts? Again thank you very much for the response. Happy Holidays! rb12
      • Akitu
        • Oct 2010
        • 2595
        Re: AR-201
        You'll need to reset the maintenance counter as well with sim 20, or the light will never go away. Quite welcome, CHLDZ0035QS51 is the part number for the whole charge unit if you need to replace.
