sharp mx 2300 printing issues.
+ More Options
Posts
  • DINGO
    • 661
    good night friends.
    i need your opinion about an issue that today i not fix.
    i have a costumer document in pdf format that the blue color print in blak?
    i try everything, pcl5,pcl6 and ps drives, i try to print as image, i try in photo,and so, and no solution, every blue print in black.?
    of corse i have the copier whit the latest firmware, and all drives are the latest.
    i try print in a ricoh copier that the costumer as, and print good.
    Any idea, i,m glad.
    thanks in advance
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sharp mx 2300 printing issues.
    Originally posted by DINGO
    good night friends.
    Any idea, i,m glad.
    thanks in advance
    Try sending the file as "Download Fonts" under the Advance tab of the Printing Preferences instead of the default "Resident Fonts".
    • DINGO
      • 661
      friend, i already try this option, and not work to.
      thanks
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        If all else fails, I've concluded that a large portion of odd printing problems are related to the 256MB in DIMM slot 2. If nobody else has a better solution, I would try replacing that. However, I'm certain there are better solutions available.
        • DINGO
          • 661
          hi friend, i will try that, because i have another error in this copier, that was, when i try print in 4bit mode, e get error, may be a memory issue?
          thanks
          • mojorolla
            The Wolf
            • 2630
            Have you calibrated the print side lately? If you print out 64-5, what do the blues look like?
            • igi
              • 1507
              Hi
              try loading the job on the usb drive
              and print directly from copier,that way you bypass all the drivers
              narowing down the problem
              • DINGO
                • 661
                hi friends.
                all your sugestions i alreadyn test, and without sucess.
                Now i go print in another mx-2300n and asfter i say somthing.
                thanks very much
