AR-M237 Fuser lamp indentification?
+ More Options
Posts
  • Buddy
    • Aug 2009
    • 285
    I'm trying to determine which lamp is the sub and which is the main. There's no wattage stamped on them. I did see 1256 & 1265 stamped on them, but they don't cross reference to anything. Thanks.
  • bilyahn
    • Dec 2006
    • 1470
    Re: AR-M237 Fuser lamp indentification?
    Normally with fuser lamps they have a tabbed end and the markings are face up as you look at them. Can't for the life of me remmber which is which at the moment but that has been true of Sharps for a while now.
    Good luck.
    Bil
      • 22997
      The simplest way to tell is where the tightest coils of the lamp element are positioned.
      Main: Tightest coils toward the center
      Sub: Tightest coils toward the ends
      If the parts illustration is correct, the sub (RLMPU0027QSZZ) is on top, with the lamp "nub" closer to the front.
      The main (RLMPU0026QSZZ) appears to be on the bottom, with the "nub" closer to the rear.
      Does that help? =^..^=
      • Buddy
        • Aug 2009
        • 285
        Big thanks Black Cat!
        • Buddy
          • Aug 2009
          • 285
          FYI Blackcat - The numbs are in the same place. They do look different in the parts guide though. Thanks again.
            • 22997
            It was a good idea to look for the lamp wattage. Sharp isn't always very helpful in that respect though.
            You didn't ask the next obvious question: How do you tell where the coils are densest if the lamp is opaque/frosted?
            Just wipe down the lamp with alcohol. Frosted lamps become transparent when wet, and alcohol will not harm a halogen lamp.
            This is how we used to confirm a bad halogen exposure lamp. It will meter infinite resistance of course, and show the silvery rings inside the quartz jacket (tungsten leaving the element), and maybe even see arcing at the lamp terminals, but you can also see the break in the element. Most MFP's these days use fluorescent or xenon or LED lamps which rarely need to get cleaned (or replaced), but on the early analog machines the super hot halogen lamps would collect airborn toner and have to be cleaned, usually with something fairly harsh like trichlorethylene then rinse off any residual oils with alcohol. The moving tabletop machines were known for this.
            It was a surprise the first time I cleaned one of those lamps and noticed that they become transparent when wet. =^..^=
