New ARM455 doc feeder has trouble picking up las page in a stack of documents when copying or scanning. Adjusted sep pad and occasionally double feeds paper in stack but now can pickup last page in stack. If I return the sep pad to its origional position-no double feeding but last page again jams frequently. Suggestions?
Brand New Sharp AR-M455 doc feeder trouble
sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comTags: None -
Re: Brand New Sharp AR-M455 doc feeder trouble
Thanks for the replies. Much appreciated.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Have you tried downgrading the separation pad to the type in the EF1 (on the AR-450)?
I've had very good results. I was setting up these machines when they were new, and we were getting DF calls within a week of placement. Sean and I lined up an AR-450 next to an AR-455, and piece by piece identified the differences. I seem to recall it being about $50 in parts, and within a few weeks we were doing it on setup.
This thread has the details:
=^..^=If you'd like a serious answer to your request:
=^..^=sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
There is a tech. bulletin for that. MFP-TB-100 Sharp-PC Service > Home > Passthroughs > Sharp-Start LoginComment
DSPF techpub.pdf Posting the modification Blackcat & BMSinc mentioned so others may benefit as well. Thanks guys. Bumping your rep power!sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Just for clarity, the "blackcat" version was being used 5 months before the original bulletin and is similar but not exactly the same. I didn't much care for the Sharp mod parts and only installed two kits before reverting to the original EF1 parts.
PS: Thanks for the rep points. =^..^=If you'd like a serious answer to your request:
Your blackcat mod------------"These are the parts required to downgrade the separation:
PSHEZ4847FCZZ Separation Pad Only
MSPRT2864FCZZ Separation Spring
LPLTP5747FCZZ Separation Plate
MSPRP2832FCZZ Leaf Spring
PSHEP4848FCZZ Mylar
PSHEP4878FCZZ Mylar
The various update kits never did return to the original tried-and-true EF-1 separation. If you are not familiar with the older separation, the parts stack up as follows: Bracket, Leaf Spring, Thick Mylar, Sep Pad, Thin Mylar, and Screw. The rest is pretty much self explanatory."Last edited by blazebusiness; 01-10-2012, 03:56 AM.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Does this mean success, or failure, or somewhere in-between? =^..^=If you'd like a serious answer to your request:
Also, the dspf mod in the techpub was installed standard on this unit ---- no mod needed. The complete sep assy for the EF-3 is available as an assembly now - Part# CPLTM5746DS51 and backward compatible with the older EF-1 feeder. The only difference between the modified new sep assy and the old style EF-1 sep assy is the addition of spacer LPLPT7040.
So , I'm stumped as to what to try next. Current firmware installed. DSPF mod done. Sharp is a new copier sold just 2 months ago - with almost no miles on it with the EF-3 randomly feeding 2 sheets at once when scanning to the computer so the customer is missing a page or two of the scan. The same jobs scanned from their Konica C550 scans with no missing pages.Last edited by blazebusiness; 01-10-2012, 04:40 AM.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Hi
just to let you know there was a modification and a new sep pad assembly can be ordered, usually corrects issue, have 300 of these in my fleet and seen this a couple times.
Also on about 35 models i had to replace the adf wiring harness, as insufficient power was actuating lift gate solenoid in the top cover harness replacement have solved many of the issues.
also you can cut off the sheath over the adf to mfp wiring and check for damage on a brown wire, ie white line fold bend issue
pain in the ass job estimated time if you have never done one 2 hour minComment
