Customer called with u2-40 after changing toner cartridge. Don't know if it was immediate or after making some copies. I brought a replacement cartridge and machine was working. These are OEM cartridges. Next day customer called about a lot of smearing of image on copies. I have attached copy for you to see.
I swapped the cartridge again and it started working okay. The next day after about 300 copies the smearing was back. I cleaned the main charger and the copies were back to normal . I ran 300 copies of a test sheet and all were good. This morning I received another call that smearing was back.
It just looks smeared but has nothing to do with fuser as image is fused and it had that look before reaching fuser as I had stopped machine in cycle. I guess if i swap process unit and dv unit it will take care of problem but I want to identify the specific cause. What bothers me is i did 2 different things and each one brought copies back to normal. I have gotten bad copies before but this has that contamination type look but if developer was contaminated I don't see how doing what I did would have changed anything.Would like to get some input. Frank/ActionPhotocopy
