Sharp AR-M257 Showing 11 x 17
+ More Options
Posts
  • Tech2002
    • Aug 2008
    • 334
    Got a Sharp AR-M257 that when I lift the Doc Feed and it reads the Original as 11 x 17 on the platten when there is nothing on the platten.
    Updated Firm - same.
    Went into System Settings and put everything back to Factory - same issue.
    When I turn off and turn back on the system, everything is fine until I open the Doc Feed.
    Any suggestions?
    Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Sharp AR-M257 Showing 11 x 17
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2606
      Try cleaning the platen glass. The auto size sensors are picking up dirty glass or are not functioning properly. The sensor name is DSIN.
      • Tech2002
        • Aug 2008
        • 334
        Issue for those that are interested - went to SIMMS 41-2 - Re-Calibrated Platen. Make sure you use 11 x 17 Paper when going through calibration & more than two-sheets if possible.
        Took care of issue - thanks for the manual offer!
