E6-11 error on Sharp MX-3501n -DIAGNOSED
  • Toner Boy
    • Aug 2007
    • 357
    Just in case anyone gets this code, we went through a bit of trouble to get it resolved; turned out to be the DSPF controller board (aka SCU PWB?). Lamp was turning on, but no data was logged in Sim 63-1 for DSPF values. Lamp would only flash once (long). Normal operation will have a short flash AFTER the initial long flash.
    Its much easier to try the board first without disassembly of the DSPF to check the CCD/lamp/wiring/etc.
    E6-11 =Trouble content CCD white scan level abnormality when the copy
    lamp is on. (MX-3501N/4501N) DSPF
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: E6-11 error on Sharp MX-3501n -DIAGNOSED
    Thanks for posting this fix, it is appreciated.
    • vic554
      I had the same issue on a mx5500 and was the fault and was the scu board as well !!
      Cheers for the info !!
      • ameritech
        • 96
        Originally posted by Toner Boy
        Just in case anyone gets this code, we went through a bit of trouble to get it resolved; turned out to be the DSPF controller board (aka SCU PWB?). Lamp was turning on, but no data was logged in Sim 63-1 for DSPF values. Lamp would only flash once (long). Normal operation will have a short flash AFTER the initial long flash. Its much easier to try the board first without disassembly of the DSPF to check the CCD/lamp/wiring/etc. E6-11 =Trouble content CCD white scan level abnormality when the copy lamp is on. (MX-3501N/4501N) DSPF
        Is this the board that is on the back of the copier where the ADF harness is connected to. Thank you
        • Toner Boy
          • Aug 2007
          • 357
          the board is actually in the document feeder itself.
