MX-2310u no initilization - display light
  • vlad_robas
    • Oct 2006
    • 225
    [Electrical] MX-2310u no initilization - display light
    Happy new year,
    Customer sayid that first time hapend afther an electrical shock. And from then on the machine is randomly not starting or not waking-up, when it does that only fans can be heard and the led from display is lighting, nothing else. In the last week it dint start at all so i did disasembled a new machine and tryed to replace PWBs and it started so i put back his own boards and it worked!!! I dont belive that machines repair themselfs so i expect at any minute to get a call from customer that the problem is back so what do u think i should do?
  • mojorolla
    The Wolf
    • 2617
    Re: MX-2310u no initilization - display light
    Try replacing the 2 DIMMS. I have also seen LVPS go bad on these but when that happens, it is completely dead, no panel what so ever.
      • 23008
      This is quite common here, surprised no-one else has mentioned this yet....
      If the machine does not boot up (but has fans running), the cause can be either the Memory/HDD, SD Card, MFP, Firmware or AC/DC Power supply.
      Check the following in this order:
      There is a small RED LED directly under the CPU heatsink on the MFP board. If this is lit, the problem is the SD Card. Replace it with spare parts version. A regular SD card will not work as it is not partitioned correctly. Spare parts version must be used.
      If the RED LED is NOT lit, the SD Card & Firmware is OK. Then check the 4 LED's near the top of the MFP near the HDD SATA cable (D22-D25). All 4 LED's should be lit. If any combination of LED's is lit or flashing, check service manual Section 6-37 for info on which combination of LED's are indicating which particular error & hardware problem.
      • vlad_robas
        • Oct 2006
        • 225
        Funny thing is that now is working so i will have to wait till error will come back.
        • Chr15tophe
          • Dec 2011
          • 42
          Before digging to deep, I'd be checking the firmware on that.. Theres a lot of updates for that model
          • Dark Helmet
            • May 2009
            • 850
            I attached a little thing we had to do on Sharp training. It has the fuse errors and the MFP LED trouble shooting. I apologize about the first one on DIMM1. I have no idea why i put B. I think it's supposed to be "on" The fan is also "on". I apologize for the chicken scratches.
