sharp ar-m451 copy distorted
  • DINGO
    • 661
    Hi friends, good morning for all.
    I need yours opinion/help, because i have a ar-m451 that i am getting a distorted copys or prints,
    when i do a duplex copy or prints, i get always one side good , and odther is distorted.
    i already replaced the ps roller unit, and test all trays without sucess.
    thanks in advance.
    • 23008
    Re: sharp ar-m451 copy distorted
    Distorted in what way, Dingo?
    Compressions, stretched images, blurry, ... be specific. =^..^=
    • DINGO
      • 661
      Hi friend
      i atached a file for ex.
      is one page that a do copy in [1][1] =[2]
      regards
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        Originally posted by DINGO
        Hi friend
        regards
        Looks like its skewing coming out of the duplex. Have you inspected the duplex unit ? How do the rollers look? What's the meter on this unit? If the ps (registration) were responsible for the skew , I think the problem would have showed up sometimes even on single sided copies. Are 2 sided copies made from the glass giving you the same problem ? If so.....you can rule out the DSPF
        • DINGO
          • 661
          hi mate, thanks for your reply.
          the problem is only in duplex copys.
          my ex. was made by using a glass, in 1 /1=2 mode.
          yes, i already give a good look in the adu unit.
          regards
            • 23008
            Is the line cross-feed or feed direction?
            The part I don't understand is the pattern, a distinct pattern on both pages, and the line is askew. Is the glass cracked?
            There has got to be more to this ... =^..^=
            • DINGO
              • 661
              hi.
              the glass is not cracked.
              i use the same pattern, and make two copies in single/ single= duplex copie.
              the notes in the second co​py, i wrote after having copied for show the problem.
              (the pattern was one and the same in both copys.)
              regards
              • DINGO
                • 661
                Hi mates
                the problem was soved, i change the ADU unit.
                regards, and thanks
                • blazebusiness
                  • 1257
                  Hi mates
                  regards, and thanks
                  I thought that something in the ADU would be the fix! Good job....glad your problem is solved.
                  • DINGO
                    • 661
                    ok, but now i must fix the ADU unit, i think the problem was in the first
                    feed rolers in the ADU unit, and i give a good look, and i think there is
                    a headache for replace.
                    regards
                      • 23008
                      I can't remember why, but I've been in the ADU before.
                      Here it is:
                      Scraping noise only when duplexing. The E-clip falls off & the shaft slides out. Shaft is located at the top of the duplexer. Disassemble the duplexer to reposition the duplex idler shaft and install an E-clip.
                      • DINGO
                        • 661
                        thanks mate, i will see.
                        enjoy your week end.
