arc-260m Drum reset
  • nmfaxman
    • 1702
    arc-260m Drum reset
    How do I reset the drum counter on this machine?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Test Command 24-07, choose which drum to reset and execute.
    • nmfaxman
      • 1702
      How do I get into service mode and how do I get the drum unit out?
      I can get into simulation but it won't let me access anything but full reset code 80.
      I have the drum unit and need to make this customer happy.
      • choicecopyguy
        • Mar 2006
        • 111
        If you are getting 80's codes you are in the "secret" service mode, don't change anything there. P*C* will access service mode. Once the dv/toner unit is out one screw and the drum unit should slide out.
        • ZOOTECH
          • 3375
          Careful, if you can get to TC 80, you are in the reserved "special access codes" area; this is, as you noticed, for setting the copier back to factory defaults.
          To enter Test Commands, press #*C* and enter your 24-7 to reset drum counter.
          To remove drum, open both front and left side doors. Pull transfer belt out half way, remove the toner cartridge and loosen the blue screw. The drum unit should slide out.
          After drum replacement, skew and focus adjustments should be done.
          Good luck
          • choicecopyguy
            • Mar 2006
            • 111
            Forgot about the T-belt.
              • 23009
              If the transfer belt is not pulled out part way the drum units will be locked, won't come out. Or something will break. Zootech gave good advice.
