MFP-TB-001..PDF
Based on the other copytechnet posts for this code I'm considering replacing the entire laser unit. Many people only replace the polygon mirror motor assembly. Thoughts? The Sharp tech bulletin MFP-TB-001 seems to indicate that only the polygon mirror motor needs replacement.
