Sharp MX-2600 Black Line on copies
  • ncengineer
    Copies have black lines on the bottom. Only copies through the document feeder tray, not scans or files sent to the copier/printer. Glass has been cleaned and checked for problems. Service technician cannot diagnose. Any ideas?
    • 23008
    Re: Sharp MX-2600 Black Line on copies
    The glass was cleaned ... but was the slit glass cleaned? Both sides? With alcohol? And the rest of the optics? Sometimes dirt on the optics can show up through the slit glass, but not off the contact glass. And the scanner rails? Were they cleaned and lubricated? Sometimes a sticky or dry scanner rail can cause the mirrors to tip at the end of the travel (under the slit glass).
    If your claims are accurate, and there is no line on prints, it is by definition an optical problem, whether its caused by the white plate, slit glass, contact glass, mirrors, or lens. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • divad2k1
        • Sep 2010
        • 147
        Also check for a scratch on the slit glass.
        • NeoMatrix
          Senior Tech.
          • 3513
          Insect in the optics.
          • costd
            • Jan 2008
            • 409
            Step one is to find an actual service tech as this is so basic even I knew it by the end of my first day.
            Look at the lines - do they go all the way across the page without a margin (I suspect not). If not, it is not the drum. Next step - take a blank sheet and make a copy from the glass. If there was a line, check ccd. If no line, make copy via DF. If you now have a line, it is someting on/under the slit glass or possibly a reflection. After a good glass cleaning, make sure you also clean the white area on the underside of the DF as it can cause a reflection.
            All the above ass_u_me you are getting the line for single sided copies/prints.
