Sharp MX 2600 Colour
  • CrapAimer
    • 296
    Hi All
    Wee priblem with MX2600 Jamming as it gets to the fuser, Tried fuser in another machine working fine. Any ideas.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp MX 2600 Colour
    Checking your jam code would be a good place to start.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • sharphead
        • Aug 2009
        • 285
        Making sure the primary transfer belt is turning, I had one jamming on entry to fusing unit. I put a mark on fusing roller primary transfer gear and secondary transfer. Primary wasnt turning took it out cleaning blade had flipped
        • Smrekca
          • Jan 2011
          • 23
          check the gear wich turns the primary transfer belt
          br
          • CrapAimer
            • 296
            Hi
            checked the gears marked them they seem to be turning ok. coming up to the fuser like a fan, looks like a registration clutch problem, but its not got one, and the motor is kicking in.
            • chubblies
              • Jun 2011
              • 155
              Remove the transfer belt drive gear, there is a pin which is driven by that gear. The housing on the gear which surrounds the pin cracks, causing jams just like you describe. You would have to remove the gear to see the problem.
              • mxm
                • Feb 2011
                • 37
                Hi
                What is the last few jam codes on the 23-2 print out
                Are there all colours on the jamed sheet or is it blank
                  • 23008
                  This issue can be caused by a faulty PTC unit. Firstly, reset the PTC unit in sim 24-04. If the machine works OK after restarting, you know the PTC unit MUST be replaced.
                  The updated part number is DUNT-8051DS15.
                  All Pastel2 series machines have this issue if the belts check OK. Also confirm that there is no PPD2_DRUM jam codes or F2-50/F2-51 trouble codes recorded, as this will indicate a problem with a flipped drum blade and/or drum phase sensor will will also cause this exact symptom.
                  • android790
                    • Jul 2010
                    • 63
                    The k drum phase sensor is a good one If you have never seen it, it will give you fits. Blackcat nailed it. There is a pub on it from the first generation series.
                    Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
                    • CrapAimer
                      • 296
                      Many thqnks for all your help, turned out to be the gear on the transfer unit was broken, working fine now
                      George
