F1-15 with FN15 on MXM623 - Symptom and Solution
  • mojorolla
    The Wolf
    • 2622
    [Error Code] F1-15 with FN15 on MXM623 - Symptom and Solution
    I had an odd call yesterday I thought would be worth sharing:
    MX-M623 with a F1-15 error code,FN15 finisher. Attempted to test the lift motor in simulation and machine locked up. Rebooted and tried again; same result. Rebooted a third time and checked the sensors of the finisher and they went high/low as normal. Went back into load test of the motors, locked up again. I then did the normal things for finisher trays, check the tracks and brackets, upper limit sensor, connector plugs, etc...all were fine. I went and got a cup of coffee and prepared to call tech support. As soon as I described the symptom of locking up during the load test, it was new control board AND the upper tray lift motor. If only the board is replaced, the motor can keep blowing out the board. Luckily, this machine was a new install and still under warranty. I installed the parts today and it worked like a charm. The lock up in service mode is a dead give away.
    Hopefully this will help someone in the future.
  • mbcruzin
    • Aug 2013
    • 142
    Re: F1-15 with FN15 on MXM623 - Symptom and Solution
    I've got an MXFN15 throwing an F1-15, F1-02. The shutter gate will stay open during long runs. Causing the machine to jam. After i clear the jam the machine will try to warm up and then Code out with an F1-15 or 02. I have discovered the the shutter gate will not close. I've replaced the motor for the shutter gate plus the sensor associated with that motor. My problem still persists. Tech support wants me to change out the wire harness and maybe the paper transport motor. Any thoughts or helpful suggestions would be welcome.
    • mojorolla
      The Wolf
      • 2622
      There is a double micro switch on the backside of the exit gate. I have seen one of the actuator arms flip outward and cause a scenario similar to what you are describing. I have an old post about this one, found here: http://www.copytechnet.com/forums/sh...highlight=FN15
