ar m550 exposure
  • pontiac
    • 420
    ar m550 exposure
    When customer is copying 2 sided the second side is showing background. Is that a exposure or transfer issue. . Which sim is used for adjusting second side exposure. Thanks for feedback.
    • 23007
    Re: ar m550 exposure
    The last time I came across this the symptoms were exactly the same as yours:
    Background on the backside of duplex copies, only when using the RSPF. Exposures have been adjusted in User Modes. Go to Custom Settings > Key Op Programs > 00000 > Copy Settings > Exposure Settings > set to "5".
    • sharpcopiertech
      try going into test command and SIM 50 to adjust the exposure. the problem sound like there is light entering the ccd and that's why your getting the background. have you try adjusting the adf and make sure is sitting on correctly. hope that helps!!
      • pontiac
        • 420
        Thanks for feed back, When i went back to customers office i was shown other docs. they had printed that reminded me of a bad laser or charge assembly, jagged print. I did the charge first no change when i did the transfer belt assembly copies came out clean front and back . Transfer unit only had 20,000 pages on it. Again thanks for replys.
