Sharp MX4100
  • mansart
    • 852
    [CQ] Sharp MX4100
    Sharp MX4100
    Customer says copies started to go light and eventually blank.
    Black and white copier are blank, color copies only show yellow.
    Sim 44-06 fails with K HV error
    Checking voltages with Sim 8-1 and 8-2, with meter, I cannot get voltage readings even close to those in display.
    Replaced HV PWB, same symptons. BW copies are blank, color copies only show yellow.
    Replaced PCU board.
    Put suspect PCU and HV Pwb to another machine and installed and both worked.
    Panic stopping the machine shows no image on Black, cyan or magenta drum.
    LSU passes internal test.
    Powering on machine, machine goes through normal warm up and goes ready, no error codes
    Any suggestions welcome.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Sharp MX4100
    Could it be something obstructing the laser for the colours in question?
    And I wonder why it's not coding out as it initializes?
    Surely it must fail drawing patches?
    • bilyahn
      • Dec 2006
      • 1470
      Re: Sharp MX4100
      You mentioned copies and not prints? Does it print okay but not copy?
      • bdcrandall13
        • Sep 2010
        • 236
        Re: Sharp MX4100
        Originally posted by mansart
        Sharp MX4100
        Replaced PCU board.
        Have you tried another transfer belt?
        • mansart
          • 852
          Re: Sharp MX4100
          It was the LSU shutters.... solenoids and dv don't generally mix well
          Thanks for replies
