tray prohibited
+ More Options
Posts
  • lazar41
    • Jun 2011
    • 8
    [Error Code] tray prohibited
    I have a mxm550 with a f3-12 code, I found paper behind tray and reset code and now the screen says copy prohibited from this tray please select another tray. I found nothing broken and tray lifts ok. Any help would be appreciated.
  • DavePo
    • Jul 2008
    • 305
    Re: tray prohibited
    Check paper tray settings under syatem settings and see if tray has been disabled for copy, print, fax, or document filing. Check appropriate boxes.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      Re: tray prohibited
      You've got to do the LCC clear in service mode.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • DINGO
        • 661
        Re: tray prohibited
        I`m with tmaged, you must performe s.m the reset code after get the error.
        good look
        • BMSInc95
          • Sep 2011
          • 66
          Re: tray prohibited
          F3-12 is tray 1 error. after removing paper from behind tray perform sim. 15.
