ICU M HDD Error
  • redserv
    • May 2010
    • 307
    ICU M HDD Error
    hi guys, i have a a client with a mx-2600n that says she was scanning something to a external pen drive, and the MFP is now dead, she said the error was
    ICU M HDD Error, i have never heard or seen anything like this with Sharp MFP's cam someone help me out if possible?thanks in advance.
  • mx270hb
    Overworked, Underpaid
    • Feb 2012
    • 26
    Re: ICU M HDD Error
    I do know a few new generation MFPs do do a scan to USB Pen .. however I'm not 100% which models do, I built one the other day.
    I'll have a look tomorrow at work for you.
    • bilyahn
      • Dec 2006
      • 1470
      Re: ICU M HDD Error
      Sounds like someone was trying to update the firmware! You may have to do an emergency boot with your thumb drive. You'll know when you get there and turn on the machine (turn off both power switches) and in the very upper left hand corner of the LCD there will be a message. If you are not getting the background light on the LCD then I would try a new hard drive or memory. Have had to initialize several of this series so far.
      Good luck.
      Bil
      BTW all Sharp MX versions scan to USB and most of the newer MXM series to as well.
      • redserv
        • May 2010
        • 307
        Re: ICU M HDD Error
        hello guys, just a quick update, i visited the client today expecting to see the MFP completely dead, however the power was off, when i booted it up,it worked, so asked the client explain to me what had happen when they got the error, she said that they were trying to scan a document to a cutomers Ipod, and everything just died, i told her the usb port can only supply a certain amount off current/voltage and its possible the Ipod could have been looking for more power than the front usb can supply, i also did a read/write test on the HDD and memory,dunno what happened but i will observe the MFP for a while, thanks again for all the advice.
        • pat284
          Re: ICU M HDD Error
          Good luck.
          Bil
          Bill, I have the same issue with MX-2600N, I see that the fix is to initilaze with emerg. boot program.. I am not sure if I have the program, do you know where and if I can get it?
          Sam
          • mojorolla
            The Wolf
            • 2627
            Re: ICU M HDD Error
            The possible cause could be a massive PostScript error, being that it is an Apple product and PS is an option on the 2600. I'm curious what the job log looks like with that type of error.
            To emergency update, change the file name to emupdate_p2.sfu. Insert the firmware jump drive and power on.
            • bilyahn
              • Dec 2006
              • 1470
              Re: ICU M HDD Error
              Sam
              It's just the ROM update placed on the root directory of a thumb drive. Have the thumb drive in the USB port when you start the copier, I had to play around with the op panel keys to get it to the ROM update (sorry don't remember the exact key sequence but it is similar to updating the ARM355's) then went from there.
              Good luck.
              Bil
              • PASTech
                • Sep 2010
                • 192
                Re: ICU M HDD Error
                Hey, I have had the machines completely 'die' while a usb is plugged into it. If you try to power cycle or wake up from sleep while the usb was plugged in the machine didn't like it for some reason. Removed the Customers usb and it worked without problem. Just in case this helps.
                What's Brown and Sticky?
                -A Stick
                • pat284
                  Re: ICU M HDD Error
                  It's just the ROM update placed on the root directory of a thumb drive. Have the thumb drive in the USB port when you start the copier, I had to play around with the op panel keys to get it to the ROM update (sorry don't remember the exact key sequence but it is similar to updating the ARM355's) then went from there. Good luck. Bil
                  Thanks Bill.. I am sorry if I sound silly but I don;t have the thumb drive that you are reffering too.. Is it a special thumb drive OR any thumb drive would work with the right ROM program? Thanks
                  • bilyahn
                    • Dec 2006
                    • 1470
                    Re: ICU M HDD Error
                    Any thumb drive as long as it's not encrypted or password protected.
                    Good luck.
                    Bil
                    • Akitu
                      Legendary Frost Spec Tech
                      • Oct 2010
                      • 2595
                      Re: ICU M HDD Error
                      Good luck.
                      Bil
                      Worth noting that it must be FAT or FAT32 format as well. Copier will not read NTFS.
