MXC402SC Lines
  • sharpie
    • Feb 2011
    • 182
    MXC402SC Lines
    I am getting a line pattern on the whole page with a blank line inserted between causing the print to be elongated and the data is being reprinted two additional times in the main scan direction (laser scan). Black only, color seems OK. I have formatted the HDD, cleared all image data, Flashed the machine, reseated all the connectors on the PCU board, replaced all the memory DIMM's on the MFP board and finally replaced the MFP board (at Sharp's instruction). Scan and fax are normal. I had the same problem on an ARM350 some time ago and replacing the MFP board did resolve the issue. Has anyone seen this or know if this is a laser unit problem. In simulation 64-5 the color and black test prints are normal. I have attached a sample. The first page is what the 2nd should look like.
  • mojorolla
    The Wolf
    • 2627
    Re: MXC402SC Lines
    Looks like electrical noise. Possibly the CCD or SCN pwb. Change the DPI or exposure with the same result? What do network prints look like?
    • sharpie
      • Feb 2011
      • 182
      Re: MXC402SC Lines
      The scans do not exhibit this problem nor do the faxes. Primarily black only in copy, print, and some simulation modes, but not 64-5 which is the PCL color test pattern. I have seen an occasional extra line in color but no background pattern.
      • Dark Helmet
        • May 2009
        • 854
        Re: MXC402SC Lines
        We had a MXC311 doing that. It was a dirty laser.
        Attached is the sample we were given showing the laser producing the bad copy.
        • mojorolla
          The Wolf
          • 2627
          Re: MXC402SC Lines
          Nice one Lawrence.
          • PASTech
            • Sep 2010
            • 192
            Re: MXC402SC Lines
            Yup, Lawrence must be a smart one .
            We just had to clean a leser on a MXC311... exactly same problem and appearance.
            What's Brown and Sticky?
            -A Stick
            • Dark Helmet
              • May 2009
              • 854
              Re: MXC402SC Lines
              Leroy was the genius for that one actually.
              • PASTech
                • Sep 2010
                • 192
                Re: MXC402SC Lines
                Sweet more Genius' to feed off of their experience and wisdom
                Hope life is going well down in the stix there Lawrence
                -A Stick
