diference between MX230FU vs MX260FU
  • vlad_robas
    • Oct 2006
    • 225
    Hello,
    What is the difference between those 2 code's? becouse i susspect that is the updated black pin which was added later to prevent the film to be teared in a few hundred copies. I'm right?
  • pixiq8884
    Re: diference between MX230FU vs MX260FU
    Originally posted by vlad_robas
    Hello,
    Nope, Mx-230FU is for Mx-2310 copier, MX-260FU is for the MX-2610 & MX-3110, MX-360FU is for MX-3610 copiers. There is no fuser unit updated part# for the blackpin modified fusers.
    • Froota
      Field service tech.
      • 129
      Should there be a way to swap both fusers? At the outside i can't see a difference, and you only get a fault code.
      I know the belt for the mx-260Fu is another partnumber, but that's it. Bit difficult then to visually make the difference.
      Regards,
      Froota
      • benn84
        • Jan 2011
        • 26
        is there a way to tell which fuser is which as i have a spare fuser unit which i want to rebuild in workshop then take to customers, the machine i have to go to is a 2310 but am unsure as to which fuser i have???
        • mojorolla
          The Wolf
          • 2627
          I cannot speak for the 2610/3610 but I know the 4111 and 5111 are the same fuser EXCEPT for the harness. I mark these with a marker as there is no visual way to tell the two apart. A 4111 fuser in a 5111 will generate an immediate H2-02. One of these days I will try swapping the harnesses and see if they can be used both ways....
          • benn84
            • Jan 2011
            • 26
            Just wondered if anyone had found a visual difference between the 2 fusers? I have a few of these units but am unsure as to which of the 2 machines it fits???
            Thanks in Advance
            • DavePo
              • Jul 2008
              • 305
              Thanks in Advance
              I may be mistaken but I think there is a difference in the cleaning rollers. If I remember correct the rollers are of different lengths. Not sure which is which off the top of my head and do not have any to look at currently.
              • Horologydoc
                • Jun 2011
                • 61
                You are right the 26/31 ppm have a longer shaft on the oil supply roller with a gear attached. Would be a quick way to tell the difference between the 23ppm and those.
