Sharp MX-M350N w FX-12
  • wpcadet
    • Jun 2011
    • 22
    It has been awhile since we have played w these. This unit is scanning each document at the speed at which they are received at the other end. Is there a way to have this unit quick scan so that the customer does not have to wait by the machine for minutes ? Firmware upgrade possibly ?
    Thanks,
    Dan
    • 23009
    Re: Sharp MX-M350N w FX-12
    Is your customer using manual transmission or memory transmission? It sounds like manual transmission to me. If yes, why? =^..^=
    • lky1978
      • Mar 2009
      • 483
      Thanks,
      Dan
      sound like your customer press "speaker" before send the documents.try to input the fax no. without press speaker then press start key, and you will know how fun with the machine.
