ar m355n energy saver
  • pontiac
    • 420
    Is there any way of turning off or disabling pre heat mode. Very inpatient user. My thought is you can't. Thanks for replys.
    • 23009
    Re: ar m355n energy saver
    The best you can do on this model is max out energy saver to 239 minutes. and auto shut off to 240 minutes. Energy saver has to be set shorter than auto shut off, or you can get some strange results. =^..^=
    • pontiac
      • 420
      Thanks blackcat. I told the customer that the energy save mode can not be turned off because of goverment regulations, We can only control the time before it kicks in. Thanks again.
      • mansart
        • 852
        destination code, tell machine it is in Canada
