Mx700 digital artifacts on prints
  • gregu33701
    • Oct 2008
    • 31
    Have a mx700 getting digital black blocky artifacts on. Print output, latest firmware tech pub I have is dated July 2008, any ideas.
  • mojorolla
    The Wolf
    • 2627
    Re: Mx700 digital artifacts on prints
    Have an example you can post? Artifacts...? Using PCL5 drivers by chance?
    • gregu33701
      • Oct 2008
      • 31
      [QUOTE=mojorolla;282083]Have an example you can post? Artifacts...? Using PCL5 drivers by chance?
      sorry about the lack of information on original post cellphones can be hard to type with
      the copier has firmware version n3.00.do doo
      the problem only exist printing pdfs from adobe acrobat x so far,tried foxit reader and prints fine, txt files and copying also print fine
      tried both pcl6 and pcl5e drivers from sharps website, the latest
      tried different pdfs, all done from pc and files i use all the time in the shop to run up machines 350n, 355n, 620, bc 320, mx4501 etc
      so pc and pdfs have never displayed garbled print/compresed black blocks before
      the copier is used,could possibly tell cust to print pdfs as image but i know something is not working right
      i enclose a sample, look at the upper right corner by number 6 you can see the black lines they look like line/blocky/digital
      thanks for any input
      are there newer firmware files, this seems like something fixed in software
      greg
      • mojorolla
        The Wolf
        • 2627
        Personally, I do not like Adobe X. If the issue is only from Adobe X, downgrade back to version 9. Also, the print as image setting should work in this instance. I have seen it correct similar printing issues.
        • MRK23
          • Jan 2011
          • 19
          The problem is within Adobe X, not the print drivers. If you search for prints with black lines while using Adobe X you shall find alot of information stating it's a problem with adobe and not any one type of physical printer or driver.
