E7-02 Laser fault AR-M237. Only happened once
  • xeroid
    Document Technologies Pro
    • 147
    Should I order a laser or does this happen occaisionally?
    • 22994
    Re: E7-02 Laser fault AR-M237. Only happened once
    I've never had a false laser error on an Andromeda, or any other Sharp. I've had the error clear for a short time (a few days, to a week), but always ended up changing out the laser. 95% of the time it doesn't clear even momentarily.
    Is that what you wanted? =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      Blackcat is correct. You can clear this error for awhile but it will lead to an L6-10 code eventually. Have had a few do this.
      Good luck.
      Bil
      • xeroid
        • 147
        Good luck.
        Bil
        Thanks for the input will get this on order
