MXM950 light cq due to toner on charging grid
  • clang
    [CQ] MXM950 light cq due to toner on charging grid
    Can't get problem to go away. problem comes back after a day.
    Sharp engereering is helping on this and we replaced:
    Pri asmy
    Devoper unit,toner/starter
    Drum /drum asmy
    Hvt pcbs.
    Transfer belt unit.
    Adjusted:
    Voltages on hvt
    Devoper doc blade/ magnet angle
    Updated software.
    No help so far ...
    Anybody else had this issue?
    Thanks,
  • igi
    • 1507
    Re: MXM950 light cq due to toner on charging grid
    Hi maybe ther is an external factors involved
    air-con near-by or a heater
    are all your cooling fans running
    good luck
    • oeshuron
      • May 2008
      • 259
      Any resolve with this issue?
      • mojorolla
        The Wolf
        • 2626
        If it happens overnight, igi may be onto something environmental being the cause. Go into SIM 44-14. It will show humidity and temperature reading in several parts of the machine. Anything odd? . Is it a foot away from the wall? If you know how to get into "super secret service mode", you can adjust the fan duties in SIM 77-23.
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          This thread is from April and the OP doesn't seem to have returned since... I don't expect anyone to get an answer. That's the hazard of necroing 4 month old threads...
